spec me an editing machine
13 Dec 2005
Reading, Berkshire
my bro needs an editing machine for his college course/university, it will run adobe premier
It needs two harddrives, 2-3Gbs of RAM, Graphics Card doesn't matter as it will not be used for gaming.
So if you could please spec me a system, Thanks
Its to early in the mornign to think straight , but :
I think thats ok , the 2.4 Core 2 for the large cache.
2 Gb of ram , got that becuase im not sure of the compatibility issuses with Ram volts and DS3 ?
DS3 - Becuase everyone loves them right ?
2 X 320Gb segates, they are fast , and large and cheaper than raptors.
PSU - someone check this ?
GFX - becuase its alright for Vista and all , but could still play games fairly well.
Case becuase its cheap.
Obv, you will have to add cd drives and such but i didnt know what so yeah. Also a budget to work to would be nice.
Also will he need monitor keyboard and mouse ?
Please someone correct this as i know there will be issues lol. Im tired :(
Rgds,
Nomisf
Needs everything?
  • Intel Core 2 DUO E6400 "LGA775 Allendale" 2.13GHz (1066FSB) - Retail £123.99
  • GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) £137.99
  • BFG GeForce 7300 GT OC 256MB DDR2 HDTV/DVI (PCI-Express) - Retail £47.99
  • Seagate Barracuda 7200.10 250GB ST3250620AS SATA-II 16MB Cache - OEM x2 £99.98
  • NEC AD7170A 18x18 DVD±RW Dual Layer ReWriter (Black) - OEM £17.20
  • Antec NSK6500 Super Midi Tower Case - 430W PSU (CA £58.99
  • Logitech Cordless Desktop EX-110 - Retail £17.99
  • Belinea 1925S1W 19" Widescreen LCD Monitor - Black/Silver £124.99
  • Asus P5B-E Plus (Socket 775) PCI-Express DDR2 Motherboard £97.99
  • Sub Total : £727.11
  • Shipping : £12.95
  • Vat : £129.51
  • Total : £869.57
:cool:
I figured someone would correct me. And that seems about right lol
eracer2006 said:
is premier optimised for dual or quad cores ?
Yes , it sure is .
Rgds,
Nomisf
xirokx said:
whats the budget?
does he need keyboard n mouse also?
budget is £1000, doesn't need a mouse & keyboard
what about a raptor, would that be good for editing?
oh and he would also need an OS Windows XP would do
I only mentioned the Raptor as im sure someone down the line would suggest it at some point. In reality a Segate .10 drive will be much better in this situation as it is large, and really rather quick, and a lot lot cheaper per GB.
Yeah Windows XP will be fine, but make sure to get XP Pro.
So in that case, i would agree with the previous spec, but ...
i would switch the Core 2 to the 1.4 with the 4 meg cahce as it will make a difference in edititng, and maybe also if you can afford it get a better PSU.
But other than that it seems fine.
Rgds,
Nomisf
Either one of the above specs will be perfect, the 6600 would be better for video work though. I'd consider a Raptor too as you could load Windows and Apps on it and then have the 2x320gb drives for storage and rendered/output files
