- 10 Sep 2008
- Bangor, Northern Ireland
A steel pot filled with sand?? I thought setting the charger on a glass chopping board was safe enough!
Good to hear Bennie!Right well im just back from walking the dog in the woods, so brought the P7 and TK21 with me to see how they faired. It was raining quite heavily so i was able to easily see the beams and the TK21 is pretty much a cone of light. The spill is so bright that at large distances I cant actually make out the bright spot in middle. In saying that though it doesn't half light up the area!
I dont really know what im complaining about to be fair, its an excellent torch and it is significantly brighter than the P7, I guess i was just hoping for more of a tight beam like the P7 but with more brightness, when in reality I not only have a brighter torch, but a much more usable area of light with the same range if not more. The P7 seems to light up the spot at large distances almost as well, however you only get that 10ft area of usable light whereas with the Fenix its more like a 35ft spread where you can clearly see everything.
How does the light output of the BC40 compare to that of a 3,500,000 candle power halogen torch?
A lot of people want super-throw until they experience a really bright light that has what i like to call a "utility beam" which is neither super-throw or super-flood, but a useful balance.
However the TK21 is perfect for what ill be using it for, so im more than happy
. remember that super-throw is actually a rather large technical challenge and you may want to head over to CPF to learn more. just watch out!
that's a complicated question. unfortunately, "3,500,000 candlepower" only means that a single point-of light at (possibly) one meter has a brightness of 3,500,000Lux. the BC40 is rated in Lumens, which is the measure of the total brightness, or the total amount of light that it produces.
there isn't any way to convert between them i'm afraid.
If you can link to the Halogen light i can do some digging for you though![]()
You can't really compare as that Sealey is more of a floodlight with a 170mm reflector. I'd imagine it would be brighter with much more flood.
Ahh, so it is. I'm getting mixed up with the halogen floodlights we have at work.
I can't believe how cheap they are. Just seen it on one site for £27. Are they any good? Seem way too cheap for that sort of power.
So... hmm. Recommendation for best bang per buck torch that is under £60, amazing flood, good throw, no longer than 20cm (preferably not above 16 ish so similar to P7 Lenser) and fairly tough/waterproof ish. Bright as possible but MUST last 2.5 - 3 hours. Do any of them last this long over 200 lumens in that size on high? Also, do they all tend to be adjustable with flood to spot control on the focus/lens part? Or are they mainly all fixed?
Torch choice is excellent. bare in mind that you are highly advised to shim the dropin to the host with copper/aluminium for heat conduction purposes.
it won't have very good runtime on high (less than two hours) but on low/medium should last for ages
Re. that charger; I've not heard anything about it which isn't necessarily a bad thing, but doesn't inspire confidence. Li-Ion cells are tempermental at the best of times, and compounded with dodgy chargers can be downright dangerous.
Of the cheap chargers, the Xtar WP2 v.2 is generally regarded as the best;
http://www.ebay.com/itm/XTAR-WP2-II-Battery-Charger-/180712649835
add a couple of reasonably good cells (Not the ultrafire 3000mAh ones!) and you should be golden.
These two reviews cover a wide range of cells. you'll note that most of the x-y-z-Fire cells don't even come close to their stated capacities.
http://www.lygte-info.dk/info/Battery 18650 UK.html
http://lygte-info.dk/info/Batteries18650-2011 UK.html
My personal cell recommendation would be anything by AW:
http://www.cpfmarketplace.com/mp/showthread.php?230876-AW-s-LiIon-Batteries-Sales-Thread-*Part-12*
as my Solarforce L2 arrived today (went for the L2 instead of the L2T as the L2T looked like it would roll around as it had no hexagonal anti-roll segment on the head).
