Spec me an upgrade
1 Dec 2006
Amsterdam, NL
No limits, but don't get the best of the best. Has to be cost effective.
I'll be upgrading the following components:
i5 3570k
Asrock Z77 Extreme4 M Intel Z77
Corsair Vengeance (16GB)
XFX 850 XXX
I'm also replacing my Lian Li PC-A04B for a Corsair 750D and going the watercooling route as I want SILENCE.
My new build has to be absolutely whisper quite at all times.
So, any suggestions? Note, I'm keeping my GPU... 980 ti.
^^1. Your processor should keep up with modern games for a while yet. I'd keep the money aside for the release of big Pascal/ Polaris and upgrade the 980ti. That'd likely provide you with a bigger performance boost than upgrading your CPU.
Yea, CPU is clocked at 4.2Ghz
I do want a bigger board and a bigger case for better cooling.
Or maybe just a bigger case? Problem is, it will look very silly having a matx mobo in a 750D
How about one of the compartmentalised cases then? The Antec P50 can take a pair of 240mm rads, the Fractal Design Node 804 looks to have several possibilities, there's also the Phanteks Evolv M-atx which is also a very good case. Plenty of cases to choose from but I really wouldn't be changing your cpu and mobo anytime soon.
