Spec me Atmos soundbar
20 Jan 2011
Wigan
Due to move house soon and I'd like to treat myself and upgrade to Dolby Atmos setup, I currently have a 5.1 setup but the misses is really putting the pressure on saying she doesn't want "loads of speakers and wires everywhere again" so I think a soundbar is the compromise, I know it won't be the same as full blown seperates.
Atmos soundbars are steep in price and having done a little research the recommend ones are around a grand! But I've seen the Onkyo LS7200 for £599 on Richer Sounds and wondered if that's any good?
has to be the yamaha one. it's pricey at £1299 but it will be worth it. anything else you buy you will always be wanting to upgrade to the yamaha. i dare you to try it out and say you don't love it. the only con is the price. but it's well worth it for what you get.
I would have thought moving into a new house its a great opportunity to get the speakers fitted properly and well hidden. No furniture etc, use flat speaker wire, hide under carpets.
Looking into it I think the best option would be to keep my speakers and buy an Atmos receiver plus extra speakers for ceiling, I'm putting my foot down lol
I thought the sony ht-st5000 was better than the Yamaha?
yamaha is the rolls royce of soundbars.
i've bought 3 and my mate just bought one too.
i've not listened to the sony but i've listened to sonos and the yamaha blows it away. it's not even a fair comparison the difference was staggering.
Yeah not doubting that.
I have the Sonos sound bar and two play 1's as rears. Need to really try and demo some of these Atmos soundbars as I am really tempted with an upgrade to one.
What one/s do you have Sonny?
i bought 1 as a present and sold one to upgrade.
i think they are ysp 2700 and ysp 1600 or their older equivalents. as they are used in bedrooms. the ysp 5600 would be overkill for a bedroom IMO however if people are spending that already on sonos then IMO it would be better to go for that.
i have a proper 5.1 setup in living room with option to go atmos 5.2.2 or 7.2 using my current AVR. this is a yamaha avr - top of the range with monitor audio speakers all round and a BK XXLS400 sub.
it's interesting to hear that new soundbars are reviewing better. i won't be upgrading the bedroom set up any time soon. but could do in a few years.
That is the general consensus amongst reviewers.
no it isn't
https://www.avforums.com/review/sony-ht-st5000-dolby-atmos-soundbar-review.13776
"our favourite Dolby Atmos soundbar is the Samsung HW-K950which has a wireless subwoofer and wireless surround speakers with built-in upward-firing drivers that allows it to deliver a genuine 5.1.4-channel experience. It's well made, sounds great and can be picked up for £1,299, making it the Dolby Atmos soundbar to beat at the moment"
The Sony HT-ST5000 is a very capable Dolby Atmos soundbar and certainly comes recommended but at £1,499 it is expensive and it simply doesn't do enough to distinguish itself from the competition.
What are my alternatives?
In terms of the competition, we have recently reviewed the Samsung HW-K850and the LG SJ9 soundbars, both of which deliver a similar front-heavy version of Dolby Atmos with overhead effects but no real surround presence. However the Samsung and LG soundbars can be bought for £899 and £799 respectively, which makes the Sony very expensive in comparison. None of them support DTS:X but the Samsung and LG soundbars do at least support 5.1 DTS, which is more than the Sony currently does. If the reports of a DTS:X upgrade to the ST5000 prove to be true then it would give the Sony the edge and help justify its price but as things stand it's at a disadvantage."
https://www.avforums.com/review/samsung-hw-k950-dolby-atmos-soundbar-review.12848
In terms of alternatives, it's worth pointing out that for £1,300 you could definitely buy a Dolby Atmos capable AV receiver and speaker package, although such an approach won't be as tidy or easy to install as the HW-K950. However if we assume that you're specifically interested in getting a soundbar and you'd like one that supports Dolby Atmos then you currently have two choices, the Samsung HW-K950 or the Yamaha YSP-5600. In terms of simple pricing the HW-K950 is clearly the winner, it's not only cheaper but comes with a subwoofer included. The YSP-5600 is also quite large, so the HW-K950 is undoubtedly easier to install, either under your TV or on the wall. The YSP-5600 creates all of its audio channels from the soundbar itself by bouncing sound beams off the side walls, rear wall and ceiling and although this approach certainly works, it will depend on the shape of your room and it does tend to create a very focused sweet spot.
The HW-K950's use of actual surround speakers creates a genuine 5.1 configuration and the Samsung has been designed to deliver an immersive audio experience over a larger area. Whilst both soundbars create the overhead channels by bouncing sounds off the ceiling and thus will be dependent on the type of ceiling you have, the HW-K950's use of rear speakers certainly helped create a better sense of sounds coming from overhead. In fact in general we found the multi-dimensional audio created by the HW-K950 to be superior to the YSP-5600 and overall we preferred the Dolby Atmos experience produced by the Samsung. The Yamaha does include four HDMI inputs, DTS-HD Master Audio/DTS:X and support for MusicCast but the YSP-5600 has a serious limitation in the fact that it can't pass HDR content. The HW-K950 has no such problems and is thus more future-proofed of the two soundbars. So although the Yamaha YSP-5600 has much to recommend, we'd be inclined to choose the Samsung HW-K950 instead."
apparently the samsung is the one to buy going off of avforums and the only competition which comes close is yamaha, however be aware one is a soundbar the other is 2 rear speakers a soundbar and a sub, so it's not a like for like comparison so that shows you how good the yamaha is as a single sound bar. i wouldn't trust reviews from anywhere else in the uk tbh. uSA has a decent forum with info but i don't feel the need when avforums is so easy to use.
so if you are after a single sound bar the yamaha is the best.
samsung has a soundbar offering which is better but it includes a separate sub and 2 rear speakers.
You quote one reviewer. The K950, although a competent soundbar obviously, has been the centre of MASSIVE levels of controversy surrounding DTS decoding and various other bugs. Don't cherry pick reviews because they support your narrative.
i only look for reviews from 3 places
avforums
hdtvtest
rtings
nowhere else. i have found them to offer the best reviews.
The YSP 2700 isn't an Atmos soundbar. I'm thinking of getting this model but it is only a 5.1/7.1 bar
Yeah I know that. The atmos model wasn't out when I bought mine or it was but it was priced at £1600.
I wanted to spend a lot less as it was for bedroom and I already have proper set up in living room. So if i wanted to experience cinema sound I go to living room for that. Where my real surround system which I can upgrade with atmos upfiring kef's if i wanted resides.
Regardless yamaha make really good soundbars at most price points.
