- 18 Apr 2011
I have a budget of up to £90 but would prefer not to spend it all I have an i5 3570k and a Asus p8z77 v lx Motherboard with corsair Vengeance ram that has the big bits on top..
I don't really want a 'giant' CPU cooler such as the mount doom ones..
I'm looking to overclock my 3570K though so I am thinking of maybe one of those all in one watercoolers such as http://www.overclockers.co.uk/showproduct.php?prodid=HS-002-IN
or http://www.overclockers.co.uk/showproduct.php?prodid=HS-009-CS&tool=3
http://www.overclockers.co.uk/showproduct.php?prodid=HS-014-CS&groupid=701&catid=2330&subcat=2262
I was also looking at other options on air such as
http://www.overclockers.co.uk/showproduct.php?prodid=HS-035-CM&tool=3
http://www.overclockers.co.uk/showproduct.php?prodid=HS-041-AR&tool=3
but i love the look of the all in one water coolers and they take up less room and look neat.
I have heard that the fans can be quite noisy on these though so i would also be looking at replacing them i can go over the budget a bit for these..
One worry i have with these all in one water coolers is that they could leak? Is there a high chance of them leaking or will i be safe with them?
