YOUR BASKET
1 x Iiyama Prolite E2483HS-B1 24" Widescreen LED Monitor - Black £119.99
1 x Intel Core i3-4130 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £89.99
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £77.99
1 x Corsair Carbide Series Air 240 High Airflow PC Case - White (CC-9011069-WW) £70.99
1 x SuperFlower Golden Green HX 450W "80 Plus Gold" Power Supply - Black £49.99
1 x Kingston 120GB SSDNow V300 Drive SATA 6Gb/s 3 2.5" (7mm height) Solid State Hard Drive - (SV300S37A/120G) £49.99
1 x Gigabyte H81M-D2V Intel H81 (Socket 1150) DDR3 Micro ATX Motherboard £40.99
1 x TP-Link AV200 Mini Powerline Starter Kit (TL-PA210KIT) £19.99
1 x Zowie N-CM Gaming Surface - Blue £8.99
1 x Silverstone 24-pin ATX 30cm Extension - White £7.51
1 x BitFenix Alchemy 8pin EPS extension 45cm - White £5.99
1 x BitFenix Alchemy Molex to 3pin x3 Fan adaptor 7V 20cm - Black £4.99
Total : £547.40 (includes shipping : ).
Ok guys, I already have a keyboard and mouse and bungee and 2x 4gb of corsair xms3 ram and a couple of ethernet cables and some Arctic MX-4 thermal compound.
have I missed anything and does this all look compatible to you?
Do you think a Gelid tranquillo heat sync will fit in the case mentioned or be too tall?
Thanks
Joe
Thanks
Joe
