Spec Me: Front Light.
14 Jan 2009
London
Looking to do some night cycling but need a good reliable front light for around £50.
It needs to have a fairly big beam as there are a few low hanging branches along the route and many potholes i would rather avoid.
The path is unlit all the way so would battery life needs to be well over an hour and reliable as i had tried the cheap ones with the battery packs and they were great at first with a very bright light but after a couple of months they would just stop working.
Any help greatly appreciate thank you.
The new (ish) Halfords bike hut light seems to be well received.
There's a four page thread on it on singletrack :
https://singletrackworld.com/forum/topic/bikehut-1600-light/
Looks to have better mounts.
They do a cheaper 800 version too.
Or as above the cateye volt series is decent. I have a volt 500. The rubber mount tends to slip a bit on rough ground though so needs pulling round a bit now and then
check the last few pages of the MTB thread.
Batteries are the biggest issue.
After having a solar storm x2 (great light) the battery pack and charger were rubbish.
And you've got extra cables to worry about.
I'm more than happy paying a bit more for a water resistant known brand with an on board battery..
For the price I would also say this too! I cycle to work cross country where there are no lights at all and this lights up the way VERY well for me. I actually use it as a backup light to my Hope r2i which is a lot brighter but a lot more expensive!
