BIGBC has got the spec bang on. Although, I would try and spend a little extra and get a better power supply.
Erm. Isn't that a AM2+ CPU in a AM3 mobo.
Swap CPU for:
AMD Phenom II X4 Quad Core 955 Black Edition 3.2GHz (Socket AM3) - Retail
and pay an extra £10 quid or so
BIGBC, you can't put an AM2+ CPU in an AM3 mobo, so either stick in the tri core in mp260767's spec or the more expensive quad mentioned above.
Oh woops, thought they were backwards compatible.
Cheers for that, saved me making a pricey mistake lol.
EDIT: can you put an AM3 CPU in a AM2+ mobo ? or have i got things really mixed up here.
Can someone check the below link.
http://img24.imageshack.us/img24/5085/23568088.jpg
Just need a PSU for a max of £80 (which will run 2x of the above cards) to bring it up to £650 inc delivery.
How far will it OC on the standard fan ?
Thx
yes the CPUs are backwards compatible with the mobo's not vice versa, AM3 has one less pin than AM2+ so the 3 CPU will go in the 2 slot, but a 2 CPU has too many pinds for a 3 slot
