- 24 Mar 2009
- Essex
I was hoping to get some suggestions for a motorised time lapse mount I can use with either a dslr or Gopro.
You could always try to make your own using something like a cheap Celestron motor drive. Your end creation may not be pretty but I can't imagine it would be too difficult to make something that does the job cheaply. Off the top of my head you could look into getting an old belt drive turntable and cannibalising it and using the telescope motor drive to attach the turntable belt to. There's many possibilities to create something yourself with that drive as a starting point.
For a Go-Pro I use an Ikea 1hr egg-timer (ORDNING) which works amazingly well.
Ksantis idea is just not the same.. It looks nothing like a motorised slider movement.. There is no parallax, a motorised slider is far better...There are very decent konovo motorised sliders.. If you are serious however, check out Kessler or PBlooms pocket dolly!!
