Spec me please
24 Mar 2009
Newcastle Upon Tyne
Hello hoping someone can help me
My current pc is dated and is running like a bag of hammers so want to upgrade [currently barton2800, 1gig pc2700, 6800gs in a raidmax sagitta case which makes your ears bleed its that loud running xp]
I use my pc mainly for net use so dont need much in the way of graphics
Things i am mainly looking for is a quick quiet pc with a lot of storage
I have around £500 to spend and would like to work around the AMD Phenom II X4 Quad Core 955 Black Edition 3.20GHz if possible
Need tower including [quiet case] and os.
If iv missed anything please let me know any help appreciated
If you are using the PC for the NET, you would be better off buying a Laptop and hooking up a 22" or 24" TFT monitor to it. Not only will it be almost silent but you will be able to add external USB2 storage drives and sound seal them in a padded case for even more silence.
I picked up a 15.4" Toshiba Dualcore 1.73 Ghz Laptop with 2MB of ram for £280 14 months ago.
And oh, you won't need to buy an operating system either as it will be pre-installed. Jusy create a backup "Installation Disk" on to a pair of DVD disks so if you need to re-install you can safely do that.
Thanks for the advice but i would still prefer a desktop pc
thats a bit more upto date than mine
dosent have to be total silent just dont want a case thats full of fans
Intel Core i5 750 2.66Ghz (Lynnfield) (Socket LGA1156) - OEM £143.03
(£121.73) £143.03
(£121.73)
Gigabyte GA-P55A-UD3 Intel P55 (Socket 1156) DDR3 Motherboard £112.98
(£96.15) £112.98
(£96.15)
OCZ Obsidian 4GB (2x2GB) DDR3 PC3-12800C9 Dual Channel (OCZ3OB1600LV4GK) £85.99
(£73.18) £85.99
(£73.18)
Microsoft Windows 7 Home Premium 64-Bit - OEM (GFC-00599) £76.99
(£65.52) £76.99
(£65.52)
OCZ StealthXStream 500w Silent Power Supply £45.99
(£39.14) £45.99
(£39.14)
Antec 300 Three Hundred Ultimate Gaming Case - Black £42.99
(£36.59) £42.99
(£36.59)
XFX ATI Radeon HD 4350 1024MB DDR2 PCI-Express Graphics Card £41.99
(£35.74) £41.99
(£35.74)
You could save some pennies by ditching the graphics card if your current one is PCI-E or go for the H55 motherboards which have inbuilt graphics and are fairly cheap.
looks like like i3 could be what you're after tbh.
Intel Core i3 530 2.93GHz (Clarkdale) (Socket LGA1156) - Retail £98.99
Patriot Sector 5 Viper II 4GB (2x2GB) PC3-12800 1600MHz Dual Channel + 3D Mark Vantage (PVV34G1600LLKB) £82.76
Gigabyte GA-H55M-S2H Intel H55 (Socket 1156) DDR3 Motherboard £74.99
Microsoft Windows 7 Home Premium - Retail (Upgrade Version) £67.99
Samsung SpinPoint F3 500GB SATA-II 16MB Cache - OEM (HD502HJ) £39.99
Corsair CX 400W ATX Power Supply (CMPSU-400CXUK) £37.99
Coolermaster Elite 335 Case - Black £31.67
Sony Optiarc AD-7240S 24x DVD±RW SATA ReWriter (Black) - OEM £18.99
Sub Total : £385.83
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £11.25
VAT is being charged at 17.50% VAT : £69.49
Total : £466.57
leaves you 30 quid to play with aswell to get some quiet fans or increase HDD capacity if you wish.
