Spec me power supply £40
9 Jan 2013
Worthing, West Sussex
Hi im looking for a psu for around £40.
Will be using it for i3 3220 cpu, hd7850 gpu, 8gb ram, dvd drive and a 1TB hard drive, fairly mid range setup so no need for anything overkill.
Obviously needs to be a decent brand and stuff.
Thanks!
The corsair looks perfect, but i've heard dodgy things about them recently? I have the fractal design 1000, and it's not the biggest case so the modular cabling would be handy. Thanks for such quick responses though :-)
Corsair are one of the reputable companies which a large portion of people would go to without even considering anyone else, like Nvidia with some people, which is why you will find more people saying its faulty because more people are buying them.
I wouldn't worry too much about it and while the caps aren't brilliant (Teapo ones I think) its the best under £40 in stock which is modular. Plus a good warranty.
I'll go for that then! It's only £39 with P+P off that online retailer named after a forest so i'll buy that once I get paid later :-) Thanks for the help
