Spec me rollers and sleeves
28 Dec 2009
Wales
Hey guys
Now that my renovations are almost done my thoughts turn to painting. Will be painting newly plastered walls and ceilings with Matt emulsion.
Can anyone recommend good rollers and sleeves? Ideally I don't want to spend an absolute fortune. Are Harris any good? Was looking at their 'T Class' trade stuff?
I'm out my depth here so any help greatly appreciated.
And
I have always led to believe lambs wool rollers are the best,i have used some in the past and they are very good.
Don't spend out on anything expensive, just some bog standard stuff from wilkos or somewhere, you're painting onto nice newly plastered walls so you're not going to need anything special!!
Nice clean newly plastered walls with loads of bits in from crappy rollers.:D
I'd go down to your local johnston's trade or dulux etc. And ask them. Johnston's are doing a roaring trade on Fat hog stuff at the moment.
Seems decent and good value
If i had just spent £100's of my money on new plaster i would not use a cheap roller,the lambs wool roller (if kept moist)will last you years.
Try the decorators choice gold sleeves and purdy contractor brushes from crown decorating centre.
Sleeves are about £3.50 and set of 5 brushes is about £18
And I would use a medium pile roller
Cheers guys for the feedback. Medium pile it is. Narrowing my search as mentioned to Lambswool though the Harris micropoly had already caught my eye. Will pop to Johnstons Tuesday and see what they can suggest.
Quick question... as all the walls and ceilings are freshly plastered is it short pile I want for roller sleeves?
yep :)
wait till the plaster is dried though
you will need to do a mist coat, (water downed matt contract emulsion) as the first coat to seal the plaster, do not use PVA Glue!
as for rollers ive tried loads in the past and now only use Purdy Cageless roller and sleeves, amazing kit!
I never clean rollers. wrap in cling film, reuse and sling.
Colour changes are a no no unless you fancy hours of cleaning.
I was always of the same thinking as this, but read somewhere to use a bit of washing up liquid when washing them. I tried this last time and it made a massive difference and the roller was properly clean in minutes and also left feeling soft ready for the next use.
yep :)
I've never painted a freshly plastered wall, but a friend who is in the trade recently did at his home and used a PVA/water mix. Is it a common misconception? Whats the issue with it?
Also what is 'matt contract emulsion'?
Oh no, you have unleashed the PVA mist coat beast! Thats my cue to head home haha!
Personally, Ive never used PVA and everyone who Ive used who is "in the know" has never used a pva base coat.
To get all the bits of fluff off a new roller blow it with an airline and if you really want to clean them to reuse then use a pressure washer.
I'd think twice about using the same roller for another colour, but I try to get a few uses out of my sleeves.
using them once and chucking them is silly. wrapping them in a bag is often risky as they can dry if you knack it up.
Where people go wrong is they stick a fully loaded roller under the tap and try to rinse it all out and give up far too early. you need to scrape as much of the paint out first. I have 2 types of roller scrapers but this tool is the most useful:
http://www.screwfix.com/p/purdy-6-in-1-painters-surface-preparation-tool/67975
a few passes with that and then you only need to rinse it for a fraction of the time you would normally.
Can't say I have any preference for rollers, but I'm not really a fan of the harris ones. I nearly always use fatHog rollers from jonstones as I just pick a few up when I go there as they're pretty cheap.
I'm going to quote myself from another thread here as this post kind o killed the thread but it's useful:
Hey,
Lots of decent advice here already so I'm only going to give you two pieces of advice:
1. Use Jonstones CovaPlus - you can get any colour matched with it too.
2. use a decent pole and roller frame for your roller - despite the size or height of the area.
Decent coverage and even looking finish comes from consistent application - holding the handle of the roller by hand and doing short 2' sections takes ages, looks messy and doesn't give good results. Instead, paint a section about 2-3 roller-widths wide from floor to ceiling with one loaded roller. there's plenty of videos on youtube showing how you do this but essentially paint a big N shape to spread the paint ont he wall and then fill in the gap by going the other way. finish that section by running the roller in the same direction the full height of the wall. start the next section with a slight overlap and back-roll to blend the seam.
it's a common mistake to think that poles are only useful for ceilings and high places - they're absolutely perfect for walls - even short ones. my frame has never been taken off the pole.
I use this one:
http://www.redlinebss.co.uk/fat-hog-roller-extension-pole-2-4?filter_name=pole (you really don't need the longer one)
it's from Jonstones' there's others like it but what's important is that it is thick, light, and locks into place. the Purdy ones are also great but a bit more expensive. Both I've mentioned are made of fibreglass and aluminium so they're very lightweight but much stiffer than those horrid steel ones you will get from B&Q
I also use a US style roller frame - which is very important too. the steel wire that bends around and goes into the roller is much thicker than a standard-issue frames so you get a much more consistent spread as there's little flex / bias towards the roller pressing harder on one end.
I do use a tray, rather than a scuttle but I have a Simms tray with a Tray arm, and I use the tray liners that go with it. I can highly recommend this if you're doing a lot of painting. I think I'd use a scuttle if I was painting an entire house one colour over a few days, but for single rooms I think a [good] tray is the way to go.
http://www.decoratingdirect.co.uk/viewprod/s/SIMMS_TRAY_ARM_KIT/
In fact, the image in that link is a pretty much ideal roller setup. it doesn't get much better or easier than that! Don't look at it as a gimmick; it's not.
oh also, another little tip since we're on the subject - sleeves have a direction to the pile which will cause them to work their way off the frame if put the wrong way around. hold it between your palms and roll it back and forward it (like starting a fire with a stick) and it will start to move out of your hands until it comes out. remember which way it wanted to go and turn it the other way - it should want to go the other way now. turn it back again to make sure..
The direction that it wants to go is the direction that you should put it onto your roller frame - if you've always been annoyed by roller sleeves working their way off the frame and having to keep sliding them back into place - this is why ;) if you have a cageless frame then this is not an issue, but not many DIY folk use them.
