spec me some hard drives?
24 Aug 2006
ive got an 80gb hd, but i need a bigger drive for storing lots of media?
what should i get
2 x 250gb in raid0
1 x 500gb
1 x 320gb
are they all equally reliable?
there all reliable if you have a decent RAID controller.
RAID makes your data less safe, and with there being two drives there's a higher chance of one failing.
is raid1 worth it? or do you think i'll be alright with a single 400-500gb drive?
you normally get some warming that a drive fails right?
In my opinion RAID1 is not beneficial in a domestic environment, all it provides is the ability to continue operating in the event of a disk failure - it's NOT a substitute for a backup.
SMART monitoring can give a warning of an impending disk problem but it can't spot everything and can also give false positives. It's better than nothing but not to be relied upon.
