Hi,
I'm looking for some quiet and good airflow PWM fans which have the same or better performance with less noise as the SP/AF120 quiet edition PWM fans I currently have are starting to have coil whine noises when RPM is above 700 and they're a little too loud for me above 1000RPM as my computer is on the desk right next to me.
The fans will be connected to the fan headers on the Asus Z170 motherboard and I will set the Standard fan profile on them in the BIOS.
I will need the following:
3x 120mm front intake which has dust filters on them
1x 120mm and 1x 140mm for my NH-D14 heatsink or 2x 120mm will do
1x 120mm exhaust
I don't really have a budget but around £13 per fan is good enough for me without breaking the wallet.
Many thanks!
1x 120mm exhaust
Many thanks!
