Spec me WC Bits
27 Mar 2016
Bristolian living in Swindon
Hi all
Can someone spec me some WC parts, Only looking to cool the CPU and looking to spend £200-£250.. Never done WC before so need something straight forward please
Cheers
There's a few good kits available that can do this. Soft tubing removes the learning curve of bending tubing.
It's worth doing your research/reading around though as you will need some knowledge of the tricks and pitfalls of water cooling. Things like how to fill, how to drain, etc.
I can't see it working out in that case, mate. I can't see how you'll fit reservoir, pump and 240 radiator between the GPU and front panel and you have no option to mount the radiator on top.
What sort of cases are ideal in a mAtx factor
Or, thinking about it, doing all I've mentioned above but get the XSPC Photon Res/Pump as it attaches to the radiator and can be fitted vertically :)
Is this any good what i put together as i have no clue whats needed other than that lot
My basket at Overclockers UK:
Total: £167.31 (includes shipping: £10.50)​
That's great thank you, Anything more bog standard reservoir not as fancy :D
Cool, & don't forget you'll need 2 fittings per unit in the loop, so 2 for the CPU, 2 for the Radiator, 2 for the Pump/Res etc.. and they need to be the same size as your chosen tubing :)
Ohhh see I didn't know that about fittings and tubing, good job you guys are here to help.. :)
