N.B. After proof reading my below post i think i'm after guidance between the boards - mainly the H67 and Z68. But please read on as i may be missing a trick...
I should add that the monitor is a keeper and i picked the Caviar Green deliberately for its low energy consumption and reliability - speed is not issue. And i chucked the 'K' in the Z68 build as i would do a mild overclock if i went down that route.
The general gist...
I’m compiling a build for a friend who lives 400 miles away, who has plenty of funds - but still doesn’t like to spend it needlessly - and needs a build to replace the PC I built him 10+ years ago!
He uses his present system for light office work, scanning/printing and studying OS maps. However, he’s recently bought a digital camera, and is a keen wildlife/landscape photographer, and will be adding Photoshop to his software list and ‘perhaps’ skills. - plus windows 7 and latest MS Office.
Keep in mind that the build will hopefully still be running in 7+ years time and relative silence and quality are key as I want all core components to, hopefully, endure his predicted timeline. I realise it will be ancient, then, in PC terms but it should still cover his needs if his usage hasn’t changed.
Below are a few builds examples – I’m leaning more towards the H67 build at present as I feel the SB, although overkill now, will have the legs on the AMD as time plods on – plus the H67 is tried and tested and the Z68 boards are on first editions and some models have started to reveal issues (from forum banter) - this is where i would appreciate Z68 guidance...
Plus, another important factor is i wont be able to maintain/update this build (other than by post) - so stability, long/quality product guarantees and 'tried and tested' are areas to keep in mind.
Anyway, pick away as i'm unfamiliar with AMD and onboard gfx motherboards:
I don't normally do spec me threads for my personal builds but a i find second opinions are always reassuring when spending someone elses money...
The general gist...
. Just as a thought, check out the Lancool k58 -
) you could go with the
