Peetee, if you have the time you should experiment with lowering the timings and raising the FSB. You've done well so far but you will probably find that you can't keep improving both at the same time for long.
You will need to raise the vcore pretty soon too because if the CPU is running faster, regardless of whether it is because of the multiplier or the FSB, it will need more volts.
Also, in very basic terms, 'dividers' are the ratio that you run your ram at compared to your FSB (or HTT in AMD64 terms). It is not essential that the calculation for determining CPU speed be 'RAM speed' X Multiplier. You can run your ram out of time with your FSB at certain ratios. Your ram might run at 200, but if you are running a divider of 5:4 then your calculation will be 240 x multiplier. Your ram will be running slower, which will affect your processing speed in real terms, but the inhanced CPU speed will more than make up for it.
Now, on these modern boards dividers are often not represented as simple ratios like 5:4 or 6:5. Instead they are represented as as 200, 166, 133 etc. I really don't know why this approach has been taken but the numbers are themselves a reflection of the comparitive speed that the ram will run at. If you pick 166 as your divider (it's often called something like memory index in the bios) your ram will not actually run that fast, but it will run at a ratio of 166:200 to the FSB. So if you push you ram back up to 200 it will push the FSB to 240. This use of dividers allows you to reach the maximum speed of your processor without the need to run your ram at ultra high speeds.
Note: When people say they want to run '1:1' that means they want their ram to run at the same speed as their FSB.
In the old days with Athlon XP chips, this divider method often had such a negative impact on performance overall (above and beyond the impact of simply lower FSBs) that it was not really worth doing. But the new AMD64 chips are virtually unaffected by the dividers. It used to be the case that you were better off running at 2000mhz without a divider than running at 2400mhz with one, but now things are different.
Anyway i have rambled on long enough. I'll try to pick this up agian tomorrow if anyone is interested.
