Speed Camera Detectors
30 Sep 2003
Norwich
[TW]Fox said:
It warns me of mobile cameras as well - all the sites they use them on are listed and updated monthly.
Ones which actually scan for mobile vans are useless anyway, all it will tell you is 'Yes, you just got nicked'.
Agreed on both counts. I used the speed camera database when it was free and it never missed a camera. These days I just don't speed *polishes halo* ;)
With mobile cameras what the detector is actually picking up is the beam which is used to measure your speed so it is as fox says just telling you that you've been nicked.
OP
1 Dec 2002
Thats what i meant by a GPS device; perhaps I should have said Satnav. I was asking for reccomendations on that.
Perhaps the Tom Tom Go 510?
Don
18 Oct 2002
Notts
I have a TT Go 510 and do not find it very good for camera detection , I use a Origin B2 as well
apparantly if you use the PocketGPSworld dtabase is better but I think it would still have problems that I wouldn't like ( lack of over speed warning , directional intelligence etc )
Man of Honour
17 Oct 2002
Never bothered with the dedicated units as I dont see the point (Barely cheaper than a PDA, more so in some cases and less flexible) but TomTom 5.1 on my PDA will only alert me to cameras on my route, it's very good indeed.
Also smaller and easier to manage than the bigger units and you have total flexibility over where you put the GPS receiver.
OP
1 Dec 2002
Do you subscribe to the Safety Cameras Plus thing?
Don
18 Oct 2002
Notts
can it be made to give an overspeed warning ?
I could live with out directional intelligence but no overspeed would be a pain
4 Nov 2003
Ashford
I have both TomTom 5 with pocket GPS camera database and a road angel 2. I dont use both that often but use the RA everytime im driving a car. The last time I went to Southampton I used both(both of which were using the latest databases), the Pocket GPS database had at least three cameras missing from it that were up and running and also two sites there were being put up that week. The road angel warned about every single one.
IMO if your getting a device to detect cameras the PGPS database is just not accurate enough you need a dedicated device. Its a nice add on to Tomtom though for what it costs if you cant afford a decent detector.
Permabanned
19 Oct 2002
POI-warner addon for tomtom allows you to set speed limits
