hilly said:Gatso's can't flash front ways. Truvelo's can.
...and you set a Truvelo off by running over the three (?) white lines/pressure sensors a few metres in front of the camera. People slamming their brakes on when they see the thing a mile off can get quite irritating.Havana_UK said:You only set Truvelos off when going towards them.
csmager said:...and you set a Truvelo off by running over the three (?) white lines/pressure sensors a few metres in front of the camera.
You only set Gatsos off when going away from them.
Hav
[ Ry ] said:Anyone know if they can get you from the front? Or anyone who knows Liverpool can they tell me what type of camera they are? Quite worried now even though I wasn't speeding.
Trifid said:What happens when you are on a bike and set off a Truvelo? Do they have rear facing camera's to get the plate?
dirtydog said:You can set Gatsos off which are facing you on the other side of the road because I've done it a number of times. I realise you can't be convicted though - or at least I assume not.
Havana_UK said:Is there any truth in that?
I'm fairly sure the white lines are just painted on the road for reference in the photgraphs. AFAIK the cameras use an infrared sensor which measures vehicle speed and determines whether it will photograph or not.
Hav
