Speed fan
13 Aug 2004
Hi
I have installed Speed fan and wasnt sure which readings reflect which temps.
After running 3dmark06
Temp 1 - 37C
Temp 2 - 34C
Temp 3 - 22C
HD0 - 32C
Core - 14C
Any ideas?
Thanks
X2 4000+
Gigabyte GA-MA69VM-S2
2GB DDR2 800
PowerColor x1950 pro AC2
WD 320GB AAKS
From those readings i would hazard a guess that temp 1 and temp 2 are your Cpu temps (one for each core) with temp 3 being the ambient temperature in the case.
The 'Core' reading is a bit baffling so can't really comment on that, with the HD0 reading being for your hard drive.
To verify the cpu temps you could try coretemp just to make sure those are accurate as coretemp is generally the most accurate.
