To be honest I was planning to select software afterwards in accordance with the spec of the computer, simply because my entire budget is currently £65 which is the reason why i was looking at combining cheaper processors. The reason for such a low budget, in case you are wondering, is simply because I am only fourteen, and so a lack of pocket money complicates things. Do you have any suggestions for the software to run the cluster?
Also in response to Delta12, my current system is an emachines E3028, meaning an intel celeron D 352, clock speed supposedly 3.2GHz, though this is probably way off (6yrs old), 2gb ddr sdram, ATI radeon xpress 200 graphics and an 80GB hard drive. I also have an acer 2000 series that crashes when you open the start menu.
