- 20 Jul 2014
- South San Francisco, CA
Welcome to my 4th Parvum Systems build... The first was Parvum Titanfall, the Second was Parvum Warfare, and most recently Tears In Rain. If you hadn't guessed yet, this one is themed around the upcoming Call Of Duty Black Ops 4 release... More on that below.
I have a thing for doing themed builds I just can't shake... I guess it's just what I do! It allows my to tap into a rich universe and pluck thematic inspiration. Something about this build style just motivates and excites me.
When I get an idea for these themed builds something usually grabs me and I can't shake it, like a gut feeling followed by complete obsession that this is the one. That happened with all 3 previous builds; there was never a question, I felt inspired and motivated for those concepts. While Black Ops "4" has a nice fitting "4" ring to it that goes with my Parvum chronology, something is pulling me in... CoD may be a controversial brand that's lost it's footing here and there, but I have faith in Treyarch despite silly rumors, and the universe is just so rich and ripe for the thematic plucking.
I designed the case and have sent said design to Parvum to work their acrylic wizardry. This one is pretty wild, here are some key features:
*Heavily customized Parvum Systems R1.0 case w/ quad layers and custom engraving work
*Armor cladding design w/ battle damage having tore several holes in the case
*MATX w/ motherboard orientation the same as Parvum Warfare, except bottom of GPU will show through front of case (battle damaged hole)
*Front of case logo will be displayed on a 5" LCD display visible through a battle damaged hole in the front
*Floor, roof, and rear panel water distribution plates
Main Components:
Case - Parvum Systems R1.0 (Highly Customized)
CPU - AMD Ryzen Threadripper 1900x
Motherboard - ASRock X399M Taichi Micro ATX
Memory - 16Gb (4x4) Team Group T-Force Delta RGB 3000
GPU's - 2 x Nvidia GeForce GTX 1080's
SSD - 2 x Samsung 970 Evo M.2 250Gb (Raid 0) + TBD
PSU - EVGA SuperNOVA P2 1200w
Watercooling Components:
CPU Block - HEATKILLER IV PRO for Threadripper COPPER NICKEL (Product #18026)
GPU Block's - 2 x HEATKILLER IV for GTX 1080 - ACRYL Ni (Product #15576)
GPU Backplates - 2 x HEATKILLER IV eBC - Backplate for GTX 1080 (Product #16063)
Radiators - 1 x 360 HEATKILLER TBD, 1 x 240 HEATKILLER TBD
Pump/Top Combo - WCP D5-VARIO with HEATKILLER® D5-TOP (Product #30009)
Fittings - Barrow - all gold
Tubing - Barrow 14mm chrome plated tube
Coolant - TBD
Miscellaneous:
Lighting - DarkSide RGB
Fans - 5 x Noctua NF-P12 Redux-1700
Cables - Ensourced Custom Sleeved Cables
Built-in Display - 5 Inch Waveshare Capacitive Touch Screen
