Spot the difference
the hdd looks different and maybe thats why the jumpers have different function.
hdd 1,3,5 look same and 2,4 look same if that helps
may be there just ain't any difference from this .gif, we just "suppose" that the graphic representation is correct. Someone made that with mspaint or stg, just look at the difference in the size of the pins closed by the jumper.
The jumper can be horizontally or vertically positioned across the pins to obtain different settings, it can also be set to neutral (bios detect)
