I've got my old Chieftech Dragon sat doing nothing and I want to have a bash at doing it up as a little side project.
Having done a little search on here I think spraying the metal should be fine but not sure about the plastic.
Does it need sanding in the same way as the metal, and will i need to sand it down before I stick the base coat on.
Its blue at the moment and will probably do it pink or something for the missus.
Thanks
Thanks
You can also get craft spray paint which is designed for use on various things including plastics
only ever sprayed plastic which I knew was meant to be sprayed.
