SQL Help - Conversion of Float
31 Oct 2002
Bedfordshire/Melbourne
Howdi,
My brain is misfiring today and I cannot get this to work.
I need to convert a float (ie 20111010010101) into a a Date format I can use in SSRS (for date pickers etc) ie 01/01/2011 or 01-01-2011.
field name in SSRS if you want an to use it :) = Fields!IS_RECEIVED_DATETIME.Value
For the life of me I cannot get it to work. Would like some fresh eyes if possible.
Cheers
Saviola
As above you're probably better off doing this in the data side rather than the layout.
You can just CAST it as well unless you want a specific date format (which I don't think you will for a date picker - is this for a default value for that?) i.e.
CAST(<yourfield> as datetime)
Tried both ways but get invalid syntax all the time. I am doing it in the data and not layout, pasted the wrong variable above :)
table= ISSUES
field= IS_RECEIVED_DATETIME
I must be doing basic wrong as everything else has worked fine just the damn date conversion :)
Pick a date from your database and try putting it into those code samples posted here instead of your variable name.
SELECT CONVERT(datetime, '2011...........', 103) as mytestdate
or
SELECT CAST('2011......', datetime) as mytestdate
and see what it does with that. If that works, you might need to tell the database the format of that float (as in the number of digits before and after the decimal point). Only thing I can think of offhand.
Actually ignore my first example. the formatting applies to the variable not the result so that's totally wrong lol
The 103 should be a 0 for 6 digit float numbers, 1 for 8 digit float numbers and 2 for 16 digit.
Where are you getting your float date from? I'm not sure that's even a valid datecode.
I assume from your example above that the output should be 10/10/2011 01:01:01?
If I cast that date as a float, I get 40542.
You might end up joining each part of the number together to make a date.
Someone else might point out if I'm wrong because I'm not entirely sure!
