I think you're generally getting there so I won't distract from that.
A couple of observations:
- You may want a column in #Results to store @DB so you know where the record came from.
- You may want to use the NOLOCK hint to try and avoid lock escalation on your Parameters tables.
Example: SELECT * FROM [Parameters] WITH (NOLOCK)
Thanks - I don't need the DB identifier, as the Account number will effectively do that. I will look to throw a NOLOCK in there if I see any locks. My main problem is as above, can't get this to return any results. I'm sure it's almost there...
