Hi guys,
This is probably a very easy question for you pro's but I'm relatively new to SQL scripts.
I've created and inserted a new table in my database which contains a column of identifiers (trx_ctrl_num) and a column with dates in it (date_doc).
There are 3 tables already in the database that I need to update dates on.
Each of these contain the unique identifier column (trx_ctrl_num) in my table as well as a column with (date_doc) and another with (apply_doc).
I need a script that will update the date_doc and apply_doc with the date_doc on my new table where the trx_ctrl_num is the same as the one on my new table.
Hehe, I may need some other scripts later so if you know this one keep checking up
