Hello - no doubt this has been covered a few times, but I just wanted to check before I buy a USB DAC. Plugging in a pair of active Edifier speakers into the motherboard results in quite a bit of unwanted noise. Sounds almost like GPU coil whine, it's a bit of a squeal.
The noise seems to fluctuate in line with CPU load as far as I can tell.
Would a cheap USB DAC solve this? Or is the interference just going to come down the USB port as well? Perhaps it depends on the DAC and any filtering it may do.
