SSD advice
8 Dec 2006
Cardiff
Hi all Ive decided to take the plunge and buy a SSD for my desktop the 2 im looking at are both OCZ one is the Vertex 2 bigfoot 90 or 120GB the other is the Agility 2. Price wise the agility is £125 for the 90gb compared to £147 for the same size vertex, so what im looking for is some advice to which is the best out of the 2
thanks
The Vertex 2 will be the faster drive generally.
Both will have decent read speeds, but the Agility will be slower.
The write speed of the Vertex however will be a lot better then the Agility, so it depends on what you want the drive for tbh.
I personally bought a Vertex recently as the price difference was small enough for me to consider the extra speed worthwhile.
I went for the 120GB Bigfoot, great drive never had another ssd to compare it with. The only problem with these drives is 'once you have one you want more'!:D
I went for the C300 64gb with a asus u3s6 card which give me sata 3 and two usb 3 ports. I did this because I did not want to upgrade my motherboard as I would have to then buy DDR3 ram and a core i7 vs my 8gb DDR2 and Core2 quad 9550. My system is very fast without DDR3 and Core i7. Just upgrade you HDD with a SSD and it like going from dialup to broadband, I can never go back to the slow days.
