Hi,
I'm remotely interested in adding an SSD as my boot drive on my PC.
128GB would be fine.
Not sure what my motherboard supports off-hand but I wouldn't be surprised if it is only SATA-II - I will check tonight.
The thing is I don't know enough to determine which is a good one. For example you can get a Sandisk SATA III 128GB for £50 delivered which sounds very good value but I suspect that it is not particularly fast.
Looking at the advised read/write specs it looks good but I'm old enough to know what is advertised and what is delivered are two different things.
So how do I know what would be the best to buy.
I'm not looking to spend huge amounts but say that the Sandisk was £50 and there was a much better one for £80, I would go for the better one.
Cheers,
Nigel
Cheers,
Nigel
