SSD and WinXP
ntg
ntg
24 Nov 2008
Ok folks I need your assistance!
I've decided to buy an SSD up to £100 (it'll be either the Vertex 60gb or the C300 64gb) and I wanted to ask two questions:
a) The Vertex is about £17 cheaper than the C300, is the price difference worth it? Asking since I'm on a budget.
b) I got WinXP, what do I need to do to make sure that I can use the SSD at it's full performance (I got AHCI in my bios), aware that I can get as much as SATA II will give me? I have read the SSD FAQ here which links to OCZ forums, is that still the up-to-date instructions or has anything changes since early 2009 when the FAQ was compiled?
c) Something else I read and got me worried. I was leaning towards the Vertex 2E but it seems I have to align it (WinXP user) before I install WinXP on it. However I don't have Vista/7 so I will probably need to use a tool (diskpar?) for that. Do I really need to go through this process (not asking HOW to do it, just whether I NEED to)? Is it only related to the Vertex SSDs or to any SSD ?
Thanks a lot for all responses!
All SSDs need aligning. Windows 7 will do this for you if you install to raw space but XP won't. XP also won't pass TRIM commands so your drive will probably degrade performance-wise over time.
In summary, get Windows 7. :D
