SSD as portable drive?
IC3
IC3
3 Dec 2011
I was thinking at buying a flash drive at first, but thought about using a SSD as portable memory since they're better value.
So far I narrowed it down to SanDisk Extreme PRO or Samsung 850 EVO?
Anyone using ssd as a portable drive?
they will work yeah aslong as you connect them internally or buy a 2.5" hdd/usb dock
evo is the best imo
I was thinking of a adapter such as...
unless you mounted it internally or got a dock that connect internally
I have one and it gives me full speed,fits where a cd rom drive fits
but its easier I suppose to pickup a usb stick
