SSD drive bays space
22 Jan 2010
Brighton
i am planning on buying the antec 1200 case and also a build that includes the OCZ vertex limited edition SSD 2.5" am i correct in thinking it wont fit in the 3.5" drive bays? this might sound like a complete noob question to some people but ive never had a realy decent case or SSD before :P
Any thoughts would be helpful
Thanks.
A 2.5" to 3.5" adapter mount is a cheap extra. Cost you about a fiver. Vibration and heat not an issue with SSD and I've even seen people stick them to the case with velcro tabs.
i just screwed mine into the side of a 5.25", it does look a bit odd floating with only one side connected, but the thing is so light it really won't make a difference.
