SSD drive health
6 Sep 2016
When would you replace a NVME, with crystaldiscinfo drive health percentage? Mines still in the 70%
At ~20% do you start getting errors, BSOD or around ~10%? Or even lower than that ie 5%
I've got my old Corsair Force MP510 1.92TB in an external NVMe enclosure connected to my new Mac mini. I bought it in July 2019 and it spent its early life as the main drive in my PC. I've run some drive diagnostic software and it shows 7170 power on hours, 26.8 TB units written and 99% life percentage remaining.
When you start getting errors reported and reserved blocks being used in the SMART data that's a bigger worry than the % used. I'm always less bothered about wear on a storage drive than a boot drive.
Is that program SSD Life not still a thing on the forum these days or are we all using CrystalDiskInfo now?
I remember using it back in the day to check my drive health but doesn’t provide anywhere near as much drive info tbf.
I haven't used SSD Life for a very long time, mostly because, as you've discovered yourself, it's not much good these days.
CrystalDiskInfo is probably the most popular these days. To be honest, I'd struggle to recommend another.
Yeah it was a bit of a gimmick I guess :)
I would replace mine
When it stops working lol
Never actually had a solid state drive
Fail on me so far (touch wood)
Still using a Samsung sm951 from think
It was 2015 or so
Main thing to consider for me
Would be what's on it?
And is it important and is it
Backed up?
Everything i have has multiple backups
Even backups of backups
So I never put myself in the position where
A drive failing would be any sort of worry
Should say only have solid state drives
So restoring stuff is pretty quick
the % health is not reliable indicator of the real health of an SSD, i would ignore that and carry on using it.
I have been lucky and never had an SSD fail so I dont even worry about what the % says.
Hdsentinel is better it picks up sas drives smart data too where CDi doesn't.
Almost all of my SSD even the oldest boot drives still going strong. Performance has always been inconsistent, for various reasons.
The one I've had issues with is my SanDisk 500GB external. Which is usually encrypted. It started to occasionally corrupt so I stopped using it. It now writing slow and failing. But passes all drive tests. I know there's known issues with those drives, though not this model. Had a USB Flash drive behave similar.
