Hi guys,
Think I have a problem with one of my SSDs and just wondering if there was a way for me to test if it's dying or something else causing the issue?
Basically I have a FreeNAS box set up in the living room that has a 60 GB SSD (Crucial M4) as its main drive and then some 3TB mechanical drives for storage. If I boot the machine up from cold then there are no issues and it boots up fine. Then after a certain period of time, the SSD seems to stop working, get AHCI error messages in the FreeNAS console etc.
If I then just restart the machine using the button on the case the M4 doesn't show at all in the BIOS. However, if I then proceed to turn the machine off and start it again, the M4 shows and boots properly.
I have tried changing the SATA port used in case it was that, but that seemed to make no difference.
This drive is a couple of years old now, so there's a chance it is dying but just thought I see if there are any things I can try to confirm this or if something else might be causing the issue.
For reference, this is a fresh installed FreeNAS and the disk had the same behaviour with Rockstor installed.
Thanks
Here's an output of smartctl for the drive:
Thanks
Code:
=== START OF READ SMART DATA SECTION ===
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 100 100 050 Pre-fail Always - 0
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
9 Power_On_Hours 0x0032 100 100 001 Old_age Always - 5539
12 Power_Cycle_Count 0x0032 100 100 001 Old_age Always - 1515
170 Grown_Failing_Block_Ct 0x0033 100 100 010 Pre-fail Always - 0
171 Program_Fail_Count 0x0032 100 100 001 Old_age Always - 0
172 Erase_Fail_Count 0x0032 100 100 001 Old_age Always - 0
173 Wear_Leveling_Count 0x0033 098 098 010 Pre-fail Always - 60
174 Unexpect_Power_Loss_Ct 0x0032 100 100 001 Old_age Always - 0
181 Non4k_Aligned_Access 0x0022 100 100 001 Old_age Always - 473 209 263
183 SATA_Iface_Downshift 0x0032 100 100 001 Old_age Always - 0
184 End-to-End_Error 0x0033 100 100 050 Pre-fail Always - 0
187 Reported_Uncorrect 0x0032 100 100 001 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 001 Old_age Always - 0
189 Factory_Bad_Block_Ct 0x000e 100 100 001 Old_age Always - 49
194 Temperature_Celsius 0x0022 100 100 000 Old_age Always - 0
195 Hardware_ECC_Recovered 0x003a 100 100 001 Old_age Always - 0
196 Reallocated_Event_Count 0x0032 100 100 001 Old_age Always - 0
197 Current_Pending_Sector 0x0032 100 100 001 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 100 001 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 100 100 001 Old_age Always - 0
202 Perc_Rated_Life_Used 0x0018 099 099 001 Old_age Offline - 1
206 Write_Error_Rate 0x000e 100 100 001 Old_age Always - 0
