I can't see all the SMART data, though for that drive it's probably looking at CA id 'Percent Lifetime Used'.
It's important to remember that's just what the manufacturer has set the value to be, it usually has no relation to the actual endurance of the drive.
Looking at AD 'Average Block-Erase Count' which stands at 46, I'd expect the NAND to be capable or a figure higher than 1000 at least, probably much higher. The drive also hasn't used any B4 'Unused Reserve NAND Blocks' if that resource starts getting used then the drive may be nearing end of life.
