SSD HELP REQUIRED PLZ
2 Feb 2008
Rainham - Kent
Hi,
I have a modded bios on my Asrock p67 Fatality which allows the use of trim in a raid 0 config.
I have set up the raid 0 config but I used to use ssd life pro to see if trim was enabled but in a raid 0 config this program no longer works?
Anyone know a easy way to tell if trim is enabled and working on my pc
Big thanks!!!:D
Edit,
I have downloaded crystaldiscinfo 5.1.1 and under features TRIM is not "Grayed out" so I take it that it is working??? only AAM is grayed out.
