SSD Help!
4 Aug 2009
Bournemouth, UK
Hi Guys
Am thinking about buying an SSD HDD for the OS, Am I right in thinking you install the OS on the SSD and Programs on a normal HDD.
Which is the best SSD to use in your opinion?????
And which storage HDD do you recommend??
Thanks
Hay
just use it as a normal HDD
only thing you may be limited by is availible space in that case you need to vary where items are installed
as far as storage HDDs are concerned im fairly partial to the WD 1.5tb greens or the Sammy f3 1TB
I installed my OS and my main games that tend to be played the most on the SSD, then use my storage hard drive for programs that I don't really care about speed like iTunes, Firefox, etc etc
