SSD install, 100MB system partition
20 Mar 2007
When I installed W7 on my 80GB Intel SSD, windows decided it needed to create a 100MB partition, anyone know what it's for and can I remove it? And easiest method?
The 100mb partition is used to house boot files and WinPE files. I would recommend keeping it, since it can help in recovering your system in case you need to in the future.
Oh and if you do delete it you'll need the Windows 7 disc handy to recover your install before you can boot it again.
