SSD Installation Question
D3m
D3m
10 Sep 2012
Isles of Scilly
Im doing a complete new build all new parts apart from psu and hard drives and want to install windows 7 onto my new OCZ Agility 3 SSD. Now pardon my ignorance but is it just like installing onto a normal hard drive?
Ive read various other posts that suggest pre formatting before installing into the new build, or can I just start the pc up and format and install through the windows installation like ive dont lots of times before!
My only concern really is that its a sata3 drive and my old pc is sata2 so im not even sure how I could pre format if that is the answer :confused:
Thanks for the quick response Wazza, is that a simple case of going into the bios and setting it to ahci in there?
it will change all the hdd's intel ports to run ahci,it shouldnt be a problem if all your hard drives and dvd burner are sata
They are all sata so that should be fine, thanks again for the quick responses ;)
