SSD - Intel Vs OCZ - No RAID required
I would wait a week or so to see some reviews on the OCZ Vertex drives before answering that.
IMO Intel drives are seriously over-priced and I predict by the summer of this year there will be a bunch of other manufacturers with faster drives that cost less.
Believe it would be the OCZ Solid Series I have been initially looking at (option on a laptop.) Is there really that much difference between them? Or between them and a 7200RPM HDD?
Would only be used for OS and Pagefile.
I'm waiting for the OCZ Vertex reviews before deciding also. If the speeds etc are as good as they say then you wont get much (shoot me if im wrong) bang-per-buck better than it.
It does depend what you use them for. I think most SSDs (OCZ Core v1 through to OCZ Vertex/Apex will have similar performance in web server applications, where they are mostly doing small random reads - the universally short seek times make a huge difference, and will own even a server-class 15,000 rpm hdd. But once you start doing random writes (such as a pagefile), the older generation of SSDs have some issues around the JMicron controller. Generally the older (Core/Solid) SSDs will be faster than a HDD, but in theory there will be a big difference between those and the newer Vertex/Apex SSDs, as the latter have new controllers and/or cache added, so the occasional system lag should no longer happen.
It's probably worth going for a Vertex/Apex SSD over a Solid, but they're obviously more expensive, and we're still waiting on reviews as to real-world performance.
