SSD issues please help
25 Mar 2012
Im getting blue screen crashes after logging into windows,
Im 100% sure it has something to do with my SSD
because it has been working with a normal sata drive:
Firstly started in march with bluescreens no boot - RMA'd Mobo
so now im on second mobo - Asus Pro-v
When i recieved the mobo a month later sames issues, i have since
RMA'd two crucial SSD and got a refund to buy a Corsair one
now im still getting the same issues ocuk returned the other SSD under
incompatibilty but this is getting ridiculous now ive bot been able to
use my PC for Three Months now.
On Sun 17/06/2012 17:19:09 GMT your computer crashed
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: mv91xx.sys (mv91xx+0x25312)
Bugcheck code: 0x8E (0xFFFFFFFF80000003, 0xFFFFFFFF83A36815, 0xFFFFFFFF82D62B58, 0x0)
Error: KERNEL_MODE_EXCEPTION_NOT_HANDLED
file path: C:\Windows\system32\drivers\mv91xx.sys
product: Marvell magni
company: Marvell Semiconductor, Inc.
description: Marvell magni Windows Driver
Bug check description: This bug check indicates that a kernel-mode application generated an exception that the error handler did not catch.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: mv91xx.sys (Marvell magni Windows Driver, Marvell Semiconductor, Inc.).
Google query: mv91xx.sys Marvell Semiconductor, Inc. KERNEL_MODE_EXCEPTION_NOT_HANDLED
mv is marvell related,probably the driver itself,uninstall it and use what microsoft installs,and shift your ssd off the marvell ports entirely and use the intel sata3 port,it will be the dark blue i think not sure but manual will tell you
marvell ports are always unstable
dont want to sound dumb but where abouts do i uninstall the Marvel Driver? in safe mode and under devices?, yeah my 3GBS are light blue, dark blue are the 6 gbs
YES,always choose intel over marvell,they are more reliable,you can turn off the marvell controller/ports in the bios if not used
im running asus z68 v pro ssd on intel sata3 and no issues at all
same mobo as me mate, ill give it a go, thanks for your help, is it worth me trying to get it Rma'd and get a diffrent board?
no its that controller,they arnt as good,there the same on all motherboards from x58 upwards
test it on intel sata3 and youll see
seems to be working better, i have another issue though, ATI catalyst has completely disseapred after ive installed it and wont load on right click on dekstop either, ive installed the latest off the website yet, BF3 keeps telling me its an older version and crashes after 30 seconds of game play to a white screen, any ideas?
try uninstalling it,rebooting and delete any ati folders in c/programs
and do reinstall,disable onboard graphics in the bios,ive never had that issue with ati catalyst
The catalyst issue is a common fault, I've had it before (can't remember what I did to fix it) - google it and you'll get a lot of hits/answers on this topic.
