SSD Issues
25 Mar 2011
Just installed Windows on the SSD.
I tried to change default program install location, tried to install google chrome and it installed on the SSD instead of the HDD. Any ideas?
did you change it to custom? then point it to the hdd? you might need to create a folder on the hdd first then point the chrome installer to it
There's no option to select the location when installing Chrome.
I changed the program files dir's to the HDD in the registry as well, but didn't seem to work.
you might not be able to change it then,i dont use chrome so cant say but firefox and ie9 are the same they wont let you choose custom location
