I'm trying to install an SSD as a storage device only, this one to be specific:
http://www.overclockers.co.uk/showproduct.php?prodid=HD-168-SA
Before I move on, this is my mobo: http://www.gigabyte.us/products/product-page.aspx?pid=3978#ov
I realised I had no power/SATA cables left so I just decided to use the ones connected to the Blu Ray drive until some arrive. Anyway, in the boot, I see this:
It's listed as a slave drive, is this due to it needing a different SATA port?
Anyway, I load the system, and check the software:
How come it's unable to detect the SATA interface? Also, AHCI is disabled, which I tried to enable...
... But had no such luck. The only two options I can switch to AHCI are "PCH SATA Control Mode" (which I tried, then Windows failed to boot) and "GSATA3 Ctrl Mode", But I have nothing in them right now, maybe move SSD cable here?
Moving on, I ran a test:
Quite slow at the moment, I assume this is due to AHCI being currently disabled and the actual cable type being too slow? I guess I need something such as this: http://www.overclockers.co.uk/showproduct.php?prodid=CB-047-AK ?
Here are a few connection pics if needed:
I believe it's currently in port "SATA2_3"
Any help is greatly appreciated!
