SSD or Hybrid?
23 Jan 2010
I am not sure which one to get:
OCZ Vertex 2E 120GB 2.5" SATA-II Solid State Hard Drive:
http://www.overclockers.co.uk/showproduct.php?prodid=HD-048-OC&groupid=701&catid=14&subcat=1427
OCZ Vertex 2E Bigfoot 120GB 3.5" SATA-II Solid State Hard Drive:
http://www.overclockers.co.uk/showproduct.php?prodid=HD-060-OC&groupid=701&catid=14&subcat=1427
I have also seen this HDD but it does not quite as fast but has more storage:
Seagate Momentus XT 500GB Hybrid SATA-II
http://www.overclockers.co.uk/showproduct.php?prodid=HD-233-SE&groupid=701&catid=14&subcat=1894
I don't know what the difference between the Two OCZ SSD is except for their size. Any help or information will be really great.
Size & price is the only difference. The 3.5" is usually a bit cheaper but offers less flexibility (e.g. you can't put it in a laptop later on).
Get the bigfoot, cheaper.
If you want fast, get an SSD, if you want storage, get a mechanical. Those hybrids give you a little bit more speed, but if you can afford an SSD, then go for it!
SSD all the way. Get a green for mass storage or something a little faster if you need to store games etc.
