ssd speed problems
18 Oct 2002
Stockton.
Just noticed my system seemed to have slowed a bit..then while copying some larger files between ssd drives and my SanDisk cruder extreme usb stick I noticed once the buffer was used the speeds would drop to 100 or 150MB/sec where they used to be sustained well above 200MB/sec
I had not made any changes to the drive cables, and tried swapping both for fresh ones
I tried a secure wipe of both drives - which had a small benefit 15% or so.
Updated firmware
Also reset bios, clean window install test on both drives...
Not to no avail... Annoyingly I had a brand new system until last week that I could have tested them on..
Also checked smart and ssdlife and showed ok
Just wondering if anyone has any ideas?
