Hi there,
I recently took on my first ever build project last week. For this I ordered the overclocked bundle at 4.0Ghz which included
the Asus Rampage II Extreme Motherboard
i7 2.6Ghz @ 4.0 Ghz
6Gb of RAM
5970 Gfx card
Samsung Solid state drive
and a normal HDD
The system build went well enough with no problems and when i booted for the first time everything worked fine, the windows 7 install went well enough also.
Once i had the install complete i then inserted the Motherboard driver CD to be greeted with a message that the cd is not compatible with this OS. This caused me to panic a bit, but as everything seemed to be working okay i didnt think this would be a problem. I even went to asus support site and tried to download some drivers there myself but when i saw the list of stuff available for this board and for the windows 7 64 bit version it freaked me out. I have no idea which drivers out of the ones listed i would need. So again, as everything seemed to be working okay i left it.
Since then, the system has frozen quite a few times. I thought i had identified the problem as being Steam, but last night i left the PC on qhile downloading and woke up this morning to find it frozen. I also downloaded Prime95 to run a stress test and after a few seconds of testing the PC freezes every time.
ANy help would be greatly appreciated, thanks in advance
Finnbot
i7 2.6Ghz @ 4.0 Ghz
6Gb of RAM
5970 Gfx card
and a normal HDD
Finnbot
