Nice workDoes it give you a static IP matey? or at least something not stuck inside CGNAT?
				That sounds high - A year or so ago, I monitored my Starlink for a month and it was around 45W. Are you figures including other stuff, switch & router? These days I also put it to sleep from 1am to 7am which saves a bit more power.Also, interestingly enough, the Starlink unit seems to use quite a lot of energy. I am monitoring all the loft equipment, but at the moment it rarely drops below 65W, and is often 80w+ even with the heating option turned off.. It will be interesting to compare the two systems...
It's the whole "comms cabinet" being monitored, so it may be closer to 50w, but I will know more when I turn it off and compare to quicklineThat sounds high - A year or so ago, I monitored my Starlink for a month and it was around 45W. Are you figures including other stuff, switch & router? These days I also put it to sleep from 1am to 7am which saves a bit more power.
This all looks good but where’s the video of the dish aligning itself?
Soon.....
Check WhatsApp
Latest on this. Starlink has been rock solid, and really happy with it.. BUT... Quickline are offering 200mbps down and 30mbps uplink over a point to point 5g as they installed an AP less than a half a mile from me, by line of sight.\
Here's the kicker, its £29 a month, for the second year of the 2 year contract, and £14.50 for the first year.... At this price comparison, its a no-brainer to try it. Also, interestingly enough, the Starlink unit seems to use quite a lot of energy. I am monitoring all the loft equipment, but at the moment it rarely drops below 65W, and is often 80w+ even with the heating option turned off.. It will be interesting to compare the two systems...
I have them installing it here on the 9th of October, and I have a 30 day cancellation option if it is pants, Starlink gets to stay a little longer.
Don't mention the tree.@Malt_Vinegar how is Quickline going?
Failed install, the man was on a ladder, at first waggling a small and then excessively large erection around for ages and failed to get a satisfactory signal.@Malt_Vinegar how is Quickline going?
I am currently investigating where I can buy det-cord in the UK, unrelated to the large tree in the way a short distance from my house.
