it'll power up and do nothing (which is incidentally what generally happens when a cpu/mobo fails)You know it's a problem if you stick a working CPU in and it doesnt work.
So if I was to change my Intel CPU, and bought an AM3 board and CPU and they didn't boot, how would I know which was faulty?
For instance, would I get an POST error stating that there was a CPU error?
Always wondered this!!
Cpus with no visible damage to the underside/pins are rarely faulty. Beep codes would be another way to give you a better idea.
But to fully diagnose PC faults for sure, you tend to need to have two sets of parts. This is why there used to be more complaints in the old days about frequent manufacturer socket changes. These days we are just used to being shafted by socket changes.
Its another reason to make you stick to the same manufacturer when the socket doesnt change, though. Hence AM2 -> 2+ -> AM3.
I do have reason for asking this, as i have a on going problem with start ups.
Although i can not tell if it is the CPU or motherboard.
after serveral retries it will eventually boot it tends to start and do nothing.
(fans start, HDDs start, GFX card fan starts, CPU fan 100%, no signal to monitor)
Tested all other hardware, so i know it is the CPU or Motherboard.
but if this is the case it could lean toward the CPU not being recognised or faulty... but could mean mobo is faulty AHHH!
am wanting to replace one or the other but might be easier to replace both!
thanks
That may be a power issue had the same problem with my old setup with a hiperx psu changed it a more powerful psu corsair and never had any startup issues after that.
Out of curiosity, I once powered up an ASUS A7N something or other board without a CPU. I got a message on the monitor saying "No CPU Installed!" I was very surprised for the reasons posted above.
