start point into watercooling.
Permabanned
28 Dec 2011
Sunderland
Looking to take my first steps into watercooling and was looking for some opinions on this kit
http://www.overclockers.co.uk/showproduct.php?prodid=WC-115-EK&tool=3
Is this a good start point i have a budget in the region of 150-175 to do a cpu only loop may upgrade to include gfx if i ditch my current card and get something where i can get blocks.
also is there anything else i would require to buy alongside this kit i.e kill coil/cutters/deionised etc etc.
You would have course get better performance by picking and choosing your own components but this would end up more expensive
for the price though I cant really argue with that...
does it come with a 200mm fan? I couldnt quite figure that part out?
pop into ASDA/Tesco/Halfords and get some distilled water. Also get a funnel
you have space for a 240mm rad?
yeah i can easily fit more then 1 240 rad into my case, could fit a 360 with some modding and believe a 480 will fit if i remove the hdd bays. Ive been looking at getting into watercooling for some time now and am really wondering if i can custom build better for around the 150-170 mark I dont mind sourcing some 2nd hand gear tbh, just i dont even know where to start in regards to the equipment. Ive read the stickies etc so I suppose best thing is to get a spec me list.
If i say £200 spec me, then I should be able to surce some 2nd items like the res and rad It should pull it back towards my 170 ish budget.
